probably water in the temp sensors connections.
the temp out here is always at around 30 celcius..
for some odd reason... the temp gauge in the obc showed that
the temp is 4.5 celcius...
what the heck happened?
thanks!
today it is at -5.5 celcius
oh crap!
Mmm, check the little sensor, see what it's up to. It's on the left side of the front spoiler, kinda to the side of the foglamps, if I remember correctly, just feel around for it.
ok... this is the problem...
it happens whenever i turn on the lights....
is there some sort of connection? im totally lost on this...
thanks!
help
anyone?
Ok... so just to confirm.. what you are saying is when you turn on your headlists.. the temp drops?Originally Posted by pong
I miss my e34
You're probably in that movie: The Day after tomorrow
Sounds like a ground connection problem. If I'm not mistaken, this sensor shares a ground connection point with the headlights. Check for ground at the sensor before switching on the lights and after. There should be no difference, if there is check the ground connection at the chassis behind the left headlights. It's the only thing that comes to mind right now or the sensor could be shot.
