m20 525s are a notorious bitch to bleed, drill about a 1/16 hole in the thermostat just inside of where the black rubber o-ring fits and put it in the 12:00 position, that will help it to burp but is not allways enough on that cooling system, i try to burp as much air out as possible before starting it by squeezing the hoses and opening/closing the bleed screw, you can put your finger over the pisser hole inside of the filler neck after you squeez the top hose, let up on the hose then uncover the hole then squeze again in a pumping action, doing this in the proper order will pump the air out and suck the water out of the tank, once you get all of the air out that you can start it up and give it a 2k rpm rev and look for water comming from the pisser hole in the neck, cap it and take a short drive watching the gauge, it should be good
