Results 1 to 10 of 11
Thread: What did I miss?
    Feb 2005
    Houston, TX, USA
    Default What did I miss?
    I just replaced the upper and lower control arms. Now on the left, just as I brake into a full stop, there is a significant clunk. It clunks again when I release the brakes and start forward. This does not happen when the car is in reverse. This problem was not there before. What did I miss?
    Ryan
    1994 525iT
    you torqued the balljoint nuts right?? How bout the bolts on the other end?
    Feb 2005
    Houston, TX, USA
    I am thinking that maybe I didn't get the left lower arm ball joint tight enough, but I am open to other suggestions.
    Ryan
    1994 525iT
    did you use a torque wrench? The first time I did it I tightened it without and when I finally used a torque wrench I realized that I was nowhere close to having it tight the first time...just an idea.
    Feb 2005
    Houston, TX, USA
    Thanks. I will start there. Of course it has to be the nut that is the hardest to get to.
    Ryan
    1994 525iT
    Tampa Bay, Florida, USA
    You did torque the arms under load?
    Go over every nut you removed and check with a torque wrench.
    If you dropped the sway bar to get to the "impossible nut", make sure you have those retorqued too.
    Ramon
    1994 540iA Nikasil EAT Chip
    Tampa Bay, Florida USA
    LOL...I hate to even admit it but I replaced the pass side control arm, went all smooth then 800 miles later i hear a clunking as bad or worse than before...I missed something too. Hopefully it was the shock collar, I dont remember tightening that but remember torquing every thing else.
    Quote Originally Posted by MBXB
    Feb 2005
    Houston, TX, USA
    I just drove it again. I am pretty sure that I may have missed the left lower control arm balljoint. Can I just drop the steering arm with everything attached, torque it, then put the arm back?
    Ryan
    1994 525iT
    have to remove the plate thats held on with the 3 19mm bolts. You can leave the top bolted in and just slide the bottom to the side.
    Quote Originally Posted by rps1072
    Feb 2005
    Houston, TX, USA
    That is exactly what I wanted to hear.
    Ryan
    1994 525iT
  1. I miss my e34
    By KenB in forum 5 Series BMW
    Last Post: 05-23-2007, 09:21 PM
  2. Did I miss anything??!!
    By aston_jag_tech in forum 5 Series BMW
    Last Post: 11-03-2006, 01:23 AM
  3. did anyone miss me?
    Last Post: 06-13-2006, 03:52 AM
  4. anyone miss me?
    Last Post: 06-12-2006, 05:46 PM
