Results 1 to 7 of 7
Thread: Anybody re-finish the shifter console?
    Wichita, KS
    Default Anybody re-finish the shifter console?
    Anybody re-finished the wood? If so, what did you do to strip it and re-finish? I have fine scratches that won't polish out, nothing deep or into the wood but still annoying. I had thought of using a chemical stripper to remove the old varnish, a light sanding, then re-doing it with a hand-rubbed gloss poly. It makes for a nice finish on furniture, with the same clear, mirror like gloss as the OE finish.
    Matt J.
    '95 540/6- Jim C. chip, Bilsteins, B&B, For Sale!
    -Sold
    www.wichitabmw.com
    I think Win did this a long time ago, sanded and poly'd it, turned out real nice too.
    I did it, and it came out great but it did match the other wood in the car. I used a razor blade to slowly chip the plastic off. Light sanded and sprayed a poly with clear coat. Another light sanding and another spray coat. Be carefull because the wood is very thin. I ended up buying a new one thru BMA.
    Good Luck,
    Willobmw
    1990 535ia
    Anyone who does not have wood and would like to add a touch send me a PM.
    Jul 2004
    Vancleave, MS
    Default ...wasn't it George Mann? Check archives - been done. Devil's in the details ;-)
    Apr 2005
    IL
    It must be extremely thin ... would it be easier to sand and polish the covering plastic rather than risking destroying the super thin wood?
    Ken
    Gale did that a while back... may have been on the old board.
    http://www.nmia.com/~dgnrg/page_2.htm
    This particular feat is not on the above page but you can email him from there if he doesn't see this post.
    HTH
    - Robin
    Robin
    72 Chevy K10
    01 E39 M5
    baton rouge, loserana
    i pollished mine with a automotive rotary buffer/wool bonnet and a mild compound like you'd use on paint during a later step of buffing
    if you don't have open cracks this should work for you, open cracks would need a coat or two to even it out before buffing
  1. What holds a shifter console in place?
    By Kibokojoe in forum 7 Series BMW
    Last Post: 01-04-2009, 07:24 AM
  2. Shifter console conversion
    By bmwrp8 in forum 5 Series BMW
    Last Post: 09-16-2008, 11:42 AM
  3. Vinyl Shifter console
    By Sam-Son in forum 5 Series BMW
    Last Post: 09-09-2007, 05:48 PM
  4. Desperate need of a manual shifter console surround...
    By shrike071 in forum 5 Series BMW
    Last Post: 04-02-2007, 08:09 PM
  5. Replies: 2
    Last Post: 08-19-2006, 11:36 PM
