Originally Posted by
Jr ///M5
Original front end M5 shocks are intergal parts of the strut assembly. Meaning that you cannot remove a strut insert from the strut assembly. There isn't any. The inside of the strut assembly is filled with fluid and special valved dampers and o-rings and such, so that when you remove the strut nut, all that crap comes spilling out.
You can gut the M5 strut assembly and install the strut insert of your choice, but the original factory unit is all one piece for the front of the car.
The rears are a SLS hydraulic type system and are driven by the two stage power steering pump through accumulators and have special springs that won't work with regular shocks.
Hope this helps to answer your question.
Jr
'91 ///M5
'91 318iS
'01 525i
