Thread: Weird noise when turning
    Default Weird noise when turning
    Recently I started noticing a weird noise when I take turns. I think its been getting more and more intense. The noise seems to be coming from under the gear shifter and it sounds almost like a squaky wooden floor board...or sometimes a crack. Could it have something to do with the cold? Although I live in Seattle, it's been hitting the low 30s recently.
    Any ideas as to what it might be and if its serious enough to worry about?
    Thanks
    Aug 2005
    Toronto
    Sounds like a problem I have. I figured out it was actually people outside the car, yelling at me to SLOW DOWN!
    Now I just drive with earplugs.
    Sorry if that doesn't help
    Jay Lebo - Toronto, Canada
    1990 BMW 535i
    5-speed conversion
    Lightened flywheel
    Sachs Suspension Kit
    E.A.T. Chip
    is this on the Honda or Escalade?
    Quote Originally Posted by leetsauce4000
    Thanks
    Lexington, Kentucky
    Default Steering column
    There is an airbag slip joint on the steering column on airbag equiped e34s. it can squeak when cold because copper paste grease is no longer effective. Ask me how I know!
    Kentucky
    How do you know?
    Quote Originally Posted by Russell
    Lexington, Kentucky
    Default Saw it in the archives??
    May have seen it on Roadfly. Not sure. I was told to spread the excess copper paste around the contact area after you remove the steering wheel.
    Of course, I am assuming it is the problem. Mine does it every winter until the interior warms up, never in warm weather. I will fix when a cluster bulb burns out.
    My indy said they typically repace the contact ring which maybe a better long term solution.
  1. Noise right after turning car off...
    By HIe34 in forum 5 Series BMW
    Last Post: 12-29-2006, 05:26 PM
  2. Strange noise when turning the steering wheel
    By The Melmaan in forum 5 Series BMW
    Last Post: 12-08-2006, 07:34 AM
  3. Noise while turning?
    By Jzza4 in forum 5 Series BMW
    Last Post: 06-07-2006, 01:17 PM
  4. Weird drivetrain noise!
    By gt90 in forum 5 Series BMW
    Last Post: 09-28-2005, 05:08 PM
  5. Replies: 0
    Last Post: 09-15-2005, 10:25 AM
