to me...removed two back bolts, seatbelt bolt, and pushed the seat as far forward is it could go (it was severely pressing up against centre console....can't get the combination to make it slide out like bentley or any other procedure says...have to do both cables and rocking seat fix, so i figure i may as well get it out and do 4 or 5 rounds of leather conditioning in this stifling floriduh sun. TIA.
Here's what you need to do:
- remove headrest
- undo rear torx bolts that hold seat to floor
- undo seat belt height adjustor cable
- undo exterior seat belt attachment
- tip seat back forward using power adjust
- tip up seat frame from floor
- undo power cable from base of seat
- carefully remove seat from car
That should about do it.
Bellevue WA
86 Porsche 951 - Track Toy
