Turn the fan off. The middle knob of the controls has a setting below 1 that operates the fan at varying speeds if it is set in between 1 and off. If that's not it then hopefully somebody else will know what it is.Originally Posted by James
in the past few days I have noticed that there is always air blowing out of the vents, even if I'm stopped, and I have to keep all vents shut. Whatcould this be? Thanx
James
89 525i 285k orig. miles
it could be the final stage resistor pack (the sword) it could be shorted try turning on the fan on high and then back one notch at a time if the fan speed does not change then this is the problem
thanx for the diagnosis
The fan speed does not change, so I think that is my problem where is this "final stage resistor pack (the sword)"? Is it similar to a fuse or what Can some one tell me what the heck it is? ThanxOriginally Posted by Unregistered
James
89 525i 286k miles
Palm Springs Ca.
Go here for more info and details on repairs:
http://www.bmwe34.net/e34main/mainte...ical/sword.htm
Hope you get to fix it!
