Originally Posted by dcbimmer
Assuming it's a 5 speed, the switch is on the right side of the transmission, a 14 or 15mm hex; wiring passes up through the shifter body gasket and connects to the body wiring harness underneath the leather shift boot. Pull the boot and inspect the wiring before doing anything else -- it's possible that the wiring is cut or worn...
best, whit
