Results 1 to 9 of 9
Thread: oil change help
    Aug 2005
    Default oil change help
    sorry to bother everyone, but i just did a stupid thing and i need your help:
    i tried to change engine oil for the first time, and i got the wrong plug. the liquid is redish color. the plug is further down at the rear part of the engine. i finally located the right engine oil plug. is that transimission fluid? what should i do? thanks much.
    You were at your tranny with that red fluid... You need to replace that red fluid but we need to know what car you got... year and model to tell you what fluid it takes and how to put it back.
    what he said
    Aug 2005
    sorry, i have 535i, 1991. thanks
    Aug 2005
    east anglia uk
    Quote Originally Posted by samhahn
    auto or manual?
    Aug 2005
    it's manual. thanks.
    Mar 2004
    Lawrence, KS
    You'll want either Redline MTL or a similar quality gear fluid, you might do a search to see what other fluids are recommended, but most people seem to like Redline. You will also need a fluid pump as you must pump the fluid up into the fill hole. It's a pretty simple operation and you should do it every couple of years anyway.
    Aug 2005
    thank you very much for your help. please excuse my ignorance, but where is the fill hole?
    Fill hole on the 260/6 is on the right (passenger's in the US) side of the trans, near the top and center. You'll need a 17mm hex key if it's an early trans (would require gear oil/and NOT have a "Use ATF Only" green sticker on the bellhousing), 10 or 14mm if it's the later kind.
    best, whit
  1. 95 540 ATF change
    By kuly in forum 5 Series BMW
    Last Post: 01-09-2007, 10:59 AM
  2. How do you change your oil?
    By ILoveMPower in forum 5 Series BMW
    Last Post: 07-28-2006, 10:09 AM
  3. OT: Name change
    By infinity5 in forum 5 Series BMW
    Last Post: 04-18-2005, 09:15 PM
  4. Replies: 5
    Last Post: 11-19-2004, 08:16 PM
  5. How hard to change timing change tensioner in M50?
    By sc156k in forum 5 Series BMW
    Last Post: 06-06-2004, 11:35 AM
