Results 1 to 5 of 5
Thread: m50 belt tensioner, quick q..
    Default m50 belt tensioner, quick q..
    are the belt tensioner screws reverse thread or normally threaded? Just need to know so I don't end up with more problems than I already have...
    one of the reasons I'm broke...
    the locking bolts? those are normal thread.
    you really should put your vehicle information in your profile or signature.
    Quote Originally Posted by romeox929
    PA
    They're forward threaded but I will warn you. The accessory belt tensioner is only held on by one bolt! This is fine, but when you take it off, if you put it back on and it doesn't seem to be threading... note that the unit pivots so that the bolt hole isn't lined up on the oil filter assembly! This cost me about an hour of f-ing with it thinking I somehow stripped the bolt hole!
    stripping the bolt hole is also not a good thing.
    PA
    hard to do... i thought i had but it turned out that the mounting plate on the tensioner pivots and i was just off... confused the hell out of me.
  1. Mechanical belt tensioner pulley M50
    By russiankid in forum 5 Series BMW
    Last Post: 09-06-2008, 12:35 PM
  2. Belt Tensioner Location
    By saj3n in forum 5 Series BMW
    Last Post: 03-09-2006, 03:06 PM
  3. belt tensioner question
    By romeox929 in forum 5 Series BMW
    Last Post: 11-30-2005, 03:42 AM
  4. Seatbelt Tensioner/belt replacement
    By Tder in forum 5 Series BMW
    Last Post: 04-03-2004, 06:40 PM
  5. AC belt tensioner needs replacement
    By Phil M in forum 5 Series BMW
    Last Post: 03-17-2004, 09:13 PM
