Results 1 to 5 of 5
Thread: M50 project Con't...
    Default M50 project Con't...
    (Poor picture of) Valves with a nice coating. #5 is the problem cylinder and has considerably more 'crust'
    Anyhow, glad I took on the project, more to come....including questions like:
    Where does this go?
    Dave M
    Default Are you having the head rebuilt???
    What is your original plan?
    Where does this go?
    Dave M
    Looks like a lot of oil was getting into that cylinder. I would check the valve guides for excessive play.
    Background:
    Bottom end has ½ mill kms on it. Head rebuilt <50,000km ago. Compression test shows extremely low comp in Cylinder #5 (1/2 of all others, also I think the one you’re looking at Jeff). Cylinder ‘passes’ wet test, therefore made the executive decision to ‘rebuild’ the bottom end. Found a used block fairly cheap, had the bearings and rings done, which brings us to this point.
    Question. While I wasn’t planning on doing anything to the head, I may reconsider if folks here (jeff) feel it necessary.
    Any input appreciated,
    Dave M
    Jul 2005
    NOR CAL
    If your rebilding the whole engine you have to replace the valve seals and cleam em up a bit aswell. your going through too much trouble not to be thourogh.
  1. da new e30 project
    By winfred in forum 5 Series BMW
    Last Post: 11-05-2007, 02:50 PM
  2. my first bmw project car
    By bones in forum 5 Series BMW
    Last Post: 08-20-2007, 08:12 PM
  3. ::.. Heated Sead thread con't... cut wiring
    By Qube in forum 5 Series BMW
    Last Post: 12-03-2005, 11:15 AM
  4. 325 IS project
    By innercircle27@comcast.net in forum 3 Series BMW
    Last Post: 10-29-2004, 09:34 AM
  5. Burning oil diagnosis Con't....with pics....
    Last Post: 07-27-2004, 10:17 PM
