Results 1 to 7 of 7
Thread: E34: Wheel alignment parameters & tyre rotation
    Feb 2005
    Penang, Malaysia
    Default E34: Wheel alignment parameters & tyre rotation
    can someone tell me what is the default factory values for:
    1. camber
    2. toe in/out
    3. caster
    also what is the right tyre rotation pattern for a e34 given the
    geometry?
    Central NJ - USA
    iirc the rear can't be adjusted and the default
    values suck =]
    go with something that applies to how you drive
    lots of highway? set it up for even wear
    lots of curvy roads? setup with plenty of neg camber
    up front
    http://www.eden.rutgers.edu/~szwarc/e34/
    in there i have the bently manual it should have the specs
    for you...i'm too lazy to look it up myself =]
    adjust toe....have a nice day.
    Feb 2005
    Penang, Malaysia
    Quote Originally Posted by bahnstormer
    values suck =]
    up front
    it's taking a while to download the manual - could someone just provide me the parameters if they have the bentley manual.
    also i need advice on the right tyre rotation pattern.
    Default What vehicle do you have???
    Tire rotation is typically front to back only but it may also vary depending on what tire size/model you are using as they can be directional or staggared. I need to know the vehicle and it's suspension setup (stock or lowered) to get specs for you regarding toe, caster, camber, etc
    Quote Originally Posted by ktteoh
    Feb 2005
    Penang, Malaysia
    Quote Originally Posted by Scott H
    mine is a stock e34 520i 1993 model running on 195/60 R15 tyres all round.
    so if you can provide me:
    1. camber, caster, toe in/out, etc
    2. correct rotation pattern ...
    Default Lets see if these do the trick....
    you should stick to rotating tires front to back only and use the first column in these charts for your alignment specs.
  1. Replies: 21
    Last Post: 07-10-2007, 08:52 AM
  2. Wheel Upgrade Tyre Pressures
    By deadpheasant in forum 5 Series BMW
    Last Post: 02-02-2007, 12:19 PM
  3. BMW wheel and tyre/tire geometry/sizes explained...
    By genphreak in forum 5 Series BMW
    Last Post: 12-16-2006, 03:47 PM
  4. Tyre wear and bad judder from steering wheel
    By shuriken in forum 5 Series BMW
    Last Post: 06-10-2006, 09:21 AM
  5. Wheel Alignment
    By BennyM in forum 5 Series BMW
    Last Post: 03-25-2004, 06:35 PM
