Results 1 to 9 of 9
Thread: OBC bulbs, confirmation needed
    Sep 2004
    Default OBC bulbs, confirmation needed
    My mechanic ordered OBC bulbs for my 95 540i from the stealer. The stealer sent 6.5V green ones and insists that they are the correct ones and claims I need 4 of them. I just want to make sure that I really need the black ones (2 or 3), don't I?
    Long Beach, CA
    Quote Originally Posted by ra_pro
    I believe it was 3 on mine and the black one's are the correct fit. The green one's can melt your OBC over time. I'm pretty sure the ETK has the wrong part number.
    Perth, Australia
    no, wrong. the green 6.5v bulbs will last less than 2 weeks
    the black ones are 12v, have a bigger 'stump' bit and last for like 12 years
    why are the dealers so stupid?!
    btw you need 3, two for the sides and one at the bottom to light up the buttons
    Miami Lakes, FL USA
    Default Here's some info that might help....
    THIS:
    http://www.bmwe34.net/e34main/mainte...capacitors.htm
    is from Bruno's website.
    AND THIS:
    http://www.bimmernut.com/~billr/imag...gAndBulbs.html
    is information from Bill R.
    Both are sources that can be fairly well relied upon.............to say the least.
    I hope this helps.
    Brian C.
    Merry Christmas Everyone!
    There is nothing worse than a brilliant image of a fuzzy concept. -
    .............Ansel Adams
    Mar 2004
    It was 3 and as other have said - use the 12v (I think 1.2w but don't quote me)... And I dreaded the job because nothing ever seems to go 100% right on this car. It took 3 minutes to get the radio out (no wires to disconnect), the OBC came out in 20 secs or less (follow the procedure - flat wide item on right side, tab on left) and then the bulbs took another 5 min. I couldn't believe it and it is quite nice to have light again...
    Good luck,
    Scott
    07 525i 22K, 07 328xi (41K)
    Nov 2005
    This is what you want :
    Bulb for your OBC
    I just changed mine tonight (FINALLY ! I'm so proud of me !). You need 3 like they say.
    Albuquerque, NM
    Default Ditto, get the black ones, 3 ea.
    Get the black ones: 12V x 1.2 Watts, p/n 62 11 1 368 299
    http://www.nmia.com/~dgnrg/page_36.htm
    gale
    Apparently your dealer is WRONG!!!
    Print out this whole thread when you go back for him to see, It's really too bad the dealer insists but is wrong.
  1. Confirmation of M60 intake leak?
    By Fetch in forum 5 Series BMW
    Last Post: 11-19-2008, 12:33 PM
  2. Aussie Love In confirmation
    By GJPinAU in forum 5 Series BMW
    Last Post: 08-17-2007, 08:09 AM
  3. dash light confirmation
    Last Post: 05-09-2006, 12:21 PM
  4. Question about Depo ellipsoid bulbs--help needed
    By mikemaster in forum 5 Series BMW
    Last Post: 05-01-2005, 07:26 PM
  5. Replies: 4
    Last Post: 04-09-2005, 08:25 AM
