You might want to check the sender unit. I just had my tank refurbished last month or so and when my indy took out the sender and the pump, the sender was actually in two pieces. I would suspect that first, in your case as the pump is held in-place by a plastic basket of sorts so it is not likely to be "loose in there". This is very easy to check, wait until your fuel level light comes on then clean out your trunk, vaccuum the area around the access panel, then take the nuts off the top of sender unit. If sender is original they may be seized, soak them with penetrating oil a few days in advance. The sender then can be pulled right out, careful not to mix up fuel ines if you disconnect them. Check archives under fuel pump, Bruno has a really thorough write up on this.Originally Posted by phildg2000
