My '90 535ia w/110k had a vibration at 40-42 mph and again at 60-65 mph. New trans mounts fixed it. The strange thing was vibration was always there after a cold start, but if you let car with hot engine sit for 30 minutes, vibration was gone. The trans mounts after many years of being cooked by exhaust heat had collapsed about 3/8". This caused the u-joint to run at a greater angle then normal, which in turn caused the u-joint to operate outside the "notch" that high mileage u-joints seem to develop. Letting the hot car sit for 30 minutes allowed the exhaust heat to warm up the front u-joint eliminating this "notch" which returned the next morning. Took 2 months to figure this cycle out. I don't think your car has a guibo. Mine has u-joints at trans and center bearing and a CV joint at differential. Can you determine if replacement driveshaft was new/rebuilt or just used? If it's new/rebuilt I doubt the center brg is bad....and it should have a warranty. It's possible center bearing wasn't preloaded. Check for evidence the trans mounts are new and/or were changed.
Paul Shovestul
