Thread: New Plugs - Oil
    Default New Plugs - Oil
    Changed plugs in my '94 M60 powered 530i.
    130K miles so far on original? Bosch +2. Found a bit of oil on the freeze plugs between some of the cylinders.
    Found oil on the threads of the two plugs closest to the firewall.
    No smoke, some oil usage between changes, but not horribly noticable. I think any primary loss may be due to small seepage from the oil-pan gasket.
    Given the mileage, any concerns with slightly oily plugs?
    uberhahn
    '94 530i 5-speed. The work begins...
    thats your valve covers leaking, I have the same deal. if those plugs were original they would be horribly worn out. Change the gaskets or the oil may short the coilpacks and become very expensive.
    Maryland
    I found oil on the threads of my spark plugs... is oil seeping up through the rings into the cylinder?
    valve cover gasket dripping into the plug wells
    Quote Originally Posted by Evan
    Long Island, NY
    I had the same problem. New gaskets did the trick, but getting the covers off and on was a bitch. I left the fuel rail alone, so it took some careful twisting and turning to get the covers around especially the AC lines on the passenger side, but neither side was much fun. Other than that, easy job.
    '94 540I 6spd/205000 miles
    Maryland
    You're both right.. my valve cover gaskets need to be replaced so I just ordered them.
    I also just dropped my oil pan and there were no surprises.
    INstead of putting my car back together I keep taking it apart... and what's up with the yttrium Bosch spark plugs I bought... are they the right stuff?
  1. cold plugs or hot plugs, modified gap or stock gap...?
    By Boone.Msi in forum 5 Series BMW
    Last Post: 05-16-2007, 12:20 AM
  2. Oil on my plugs
    By 1995 525i in forum 5 Series BMW
    Last Post: 12-31-2006, 08:26 PM
  3. oil on my plugs
    By ericbendler in forum 5 Series BMW
    Last Post: 12-30-2006, 09:07 PM
  4. Plugs
    By JoshsE34-M50 in forum 5 Series BMW
    Last Post: 09-01-2004, 02:08 PM
  5. Plugs
    Last Post: 08-29-2004, 08:05 PM
