looks good, you going to cut the gauges to fit?
Things are looking good. Complete web page coming soon. I have a lot of people to thank!!!
do you know how much room is back there? That plate is a temp until I can make a nicer one. Didn't feel like spending $200 on the hartge panel. You need decent clearance back there and that requires the gauges to be held out a little.
Originally Posted by kyleN20
are the gages hooked up? If so whats the pressures and temps like when fully warm?
thats awesome. and inspiring.
180F oil temp (gauge is a bit inaccurate considering it's location...will move it soon)
20psi at idle when fully warm and up to 60psi when operating (check valve on oil pump cuts it at 60psi)
Outstanding work! Much in the way of niggling little problems to work out yet, or did you get it all perfect right off the bat? I'm impressed.
Tom Walrod
but other than forgetting to swap the starter relays and tighten the tensioner plug , it really seems to be just fine!
Originally Posted by calmloki
so when you get a nicer one will it sit that far out, or will it snug under the ash tray?/
we'll see. Dinan and Hartge ones are NLA....gotta find them used/second hand
