Results 1 to 3 of 3
Thread: Looking For Help on Cold Start Problem
    Default Looking For Help on Cold Start Problem
    I've got a cold start problem with my wife's 95 BMW 325i. It works fine in the summer, but cold weather causes the idle to surge. After the engine warms up it works fine. It was also working fine during the summer, but I had the same problem last winter. I've replaced the plugs, the idle control valve (ICV), the O2 sensor, the engine coolant temperature sensor, swapped out the Mass Air Flow Sensor, tested the throttle position sensor, cleaned the throttle body, checked for vacumm leaks. Any ideas?????????
    Wichita, KS
    Similar problems with the M60 in a 540 are usually intake gaskets. Gaskets shrink when cold, causing leaks, but as they warm expand and fix the leak. Sounds like that's the only thing you haven't tried, worth a shot.
    Matt J.
    '95 540/6- Jim C. chip, Bilsteins, B&B, For Sale!
    -Sold
    www.wichitabmw.com
    Default Thanks Matt, Does anyone else have an idea?
    Would a faulty air intake sensor or oil temperature sensor cause the idling problems?
  1. Idle problem during cold start
    By glen-sj in forum 5 Series BMW
    Last Post: 04-11-2009, 10:15 AM
  2. Cold Start, CEL problem
    By guitarfish in forum 5 Series BMW
    Last Post: 08-23-2007, 02:05 AM
  3. winter cold start problem
    By aviatorb747 in forum 5 Series BMW
    Last Post: 12-11-2006, 11:54 AM
  4. E34 m50 cold (morning) start problem
    By karmann in forum 5 Series BMW
    Last Post: 10-08-2006, 04:26 PM
  5. Cold start problem
    By peterllo in forum 5 Series BMW
    Last Post: 01-27-2005, 11:10 AM
