lets see, is this in regards to your 1971 Ford LTD?
Hi,
can anyone tell me what i need to do to install a obc if i have only 3 wires connected to the plug that is connected to the Clock?
It seems that wiring loom into the back of the clock has not a 'bunch' of wires, it contains only three wires.
Is there any chance to work around this issue???
Thanks in advance for your help.
Sorry, i have a E34, to be more precise a 525tds.
Txs!!
1971? auto? stick?
Originally Posted by lmnpd
1994, manual gear
I don't know how your german is, but the next link gives you a PDF file with a complete installation instruction for an OBC4.
I've done it with my ex 525tds and it worked!
Clickie to PDF
This World Is Mine!!
I also have just 3 wires.Originally Posted by TWISM
Twism, did you swap your entire wiringharness?
http://gunnar525.de/screwings/bc4_einbau.pdf
This pdf explains how to swap the harness, but is it really nessesary? Cant I just hook up the new wires that i need in addition to the old harness?
Espen.
You misunderstood me.Originally Posted by cschollum
I have a 525i (m50b25 // 24valves)
So i have the right display, but not the right loom...
I just added the wires into the old harness, so I didn't change the whole harness.Originally Posted by Espen
If you have the ETM for the E34 and that PDF file you can add the right wires to the old harness.
I bought the complete harness and the OBC (all from the same car, wich is identical with mine (525i, m50b25, checkcontrol)
I have switched the harness, but the OBC doesnt works, It lightens up on the buttons, but not the display...
My old harness had 2 big connectors (one black and one white) on the left side under the steering wheel.
The new harness got 3 big connectors there, 2 white ones, and one black. That means that the spare white connector doesnt have a placed to "be connected"
I measured some of the wires on the extra white connector, some of the wires goes up to the OBC connector.
What is the ETM?
