Results 1 to 10 of 16
Thread: thermostat housing gasket - silicon or no?
    Default thermostat housing gasket - silicon or no?
    as question states, I assume it would be helpful to add a layer between block-gasket and gasket-housing. I haven't noticed any mention to use it at bmwe34.net or bentley manual, so any input on this one would really help out. TIA :help
    EDIT: sorry, i have a 1991 525i with a m50 motor.
    one of the reasons I'm broke...
    Nov 2005
    Southern NH
    No need. The oring will seal the connection quite nicely. No muss, no fuss...
    Fred W
    (oo 00 oo)
    95 325i
    94 540iA
    97 Z3 2.8
    Dec 2005
    Independence Oregon USA - pop. 6000
    Doing the same job on my '93 525iT tomorrow. I don't think BMW uses silicone or gasket sealer much of anywhere. However, I'm going to the not-made by-BMW aluminum casting thermostat housing and don't trust the mating surface to be perfectly flat as BMW parts seem to be, so i will probably use a thin smear between the gasket and the housing, but not against the head. Other thoughts?
    Tom Walrod
    NO SILICONE it corrodes aluminum after time.
    if theres an O ring theres no need for anything. if it has paper gaskets use permatex spray gasket or similar.
    Nov 2005
    Southern NH
    Default No need for any goop...
    I have the aluminum t-stat covers on both my M50 and M60 engines and both sealed up nicely with just the o-ring (profile type gasket on the 6 cyl).
    Fred W
    (oo 00 oo)
    95 325i
    94 540iA
    97 Z3 2.8
    Dec 2005
    Good deal - didn't consider the O-ring for the thermostat. I'll go sans goop.
    Tom
    Houston, TX (USA)
    Default I did it without sealant but......
    found it was leaking nad had to drain and redo it with t-stat/water pump sealant. I don't know it has silicon or not, but its says "Water Pump/ T-Stat sealant" and safe for entire cooloing system. It cost a $1 only. I won't do t-stat without this sealant after this experince.
    Hope this help.
    Akhil
    theres an O-ring that goes around the thermostat itself and a separate gasket (paper?) that goes between the housing and the block. I guess permatex wouldn't worsen things, only make better?
    Nov 2005
    Southern NH
    Quote Originally Posted by romeox929
    Not on an M50 engine it doesn't. Are you sure you don't have an M20? I thought the 525 in 1991 was an M20.
    Fred W
    (oo 00 oo)
    95 325i
    94 540iA
    97 Z3 2.8
    Quote Originally Posted by FWinNH
    I don't know when they started producing m50's for 525's, but I'm positive I have a M50.
  1. Thermostat housing leak m50
    By colo525i in forum 5 Series BMW
    Last Post: 08-04-2009, 05:02 PM
  2. Question on M50 alu thermostat housing gasket
    Last Post: 12-30-2006, 08:46 AM
  3. M60 - metal thermostat housing ?
    By Super90 in forum 5 Series BMW
    Last Post: 02-01-2006, 11:57 AM
  4. Bad oil filter Housing gasket & Profile Gasket
    By mbogosia in forum 5 Series BMW
    Last Post: 01-17-2006, 09:33 AM
  5. 525 aluminium thermostat housing
    Last Post: 12-15-2005, 03:48 AM
