Results 1 to 10 of 17
Thread: E34 oil leak
    Michigan
    Default E34 oil leak
    I drive a 535i, 89 model with 140000 miles and for about two months I've been noticing an oil leak on the engine block. It's on the driver's side, below the intake and seems like coming from under the starter, I can not really locate the source, the view is blocked by the intake. Has anyone noticed something similar?
    Default The oil pan bolts can work themselves loose.......
    get under the car and look. check all the 10mm bolts. do not overtighten as torque spec is very low. try using blue loctite
    Quote Originally Posted by RAZR
    Your oil pan gasket may be split also if the bolts are too loose. Mine had loose bolts on the front right corner and the gasket was cracked up into a couple pieces at that spot, so I had to replace it.
    Its a cheap part but time consuming fix. Try Scott's suggestion first before attempting to take it apart.
    DanH
    1989 535iA 254k Miles
    1992 535iM 330k Miles
    Michigan
    Quote Originally Posted by DanH
    I will check the bolts, but as far as I remeber the leak is above the oil pan, it's coming from above the starter, th eview is blocked by the intake, but it's definitely coming from the rear of the engine.
    Michigan
    Quote Originally Posted by Scott H
    I will check the bolts, but as far as I remeber the leak is above the oil pan, it's coming from above the starter, the view is blocked by the intake, but it's definitely coming from the rear of the engine.What do you think?
    Default The oil pressure sender is up there on the head.....
    Could it be coming from that area and dripping all the way down behind the starter?
    Michigan
    From what I've read I thought it could be the oil sender unit. I can't seem tobe able to locate the oil sender unit, to physically get to feel it and check for any leaks. Any suggestions?
    Default It's on the head toward the top....
    it's at the back of the intake side. The coolant expansion tanks hides it a little bit. It's #16 in this diagram.
    http://www.realoem.com/bmw/showparts...06&hg=11&fg=15
    Michigan
    Thank you very much!!!
    Any suggestiosn as what needs to be removed to get to it?
    Thanks again
    Default You should be able to get at it without removing anything......
    stand at the driver's side and strech under the coolant tank for a good look....you should be able to snug up with a 19mm socket and extension........after you unplug it
    Thanks again
  1. Follow-up on my M50 oil leak & coolant leak
    By Dick Schneiders in forum 5 Series BMW
    Last Post: 03-06-2008, 10:51 AM
  2. M50 atf leak
    By Hozay in forum 5 Series BMW
    Last Post: 02-15-2008, 10:02 AM
  3. Oil pan leak fix?
    By Black 535i in forum 5 Series BMW
    Last Post: 10-24-2006, 04:39 PM
  4. oil leak on 90 525
    By barry 90 525i in forum 5 Series BMW
    Last Post: 09-07-2006, 06:44 PM
  5. oil leak
    Last Post: 05-01-2004, 08:44 AM
