Scotts right here, drop the pan and clean the bolt holes and use red loctite when you put the bolts back in.
Originally Posted by
Scott H
It may be to the point where the oil pump is not snug and you are losing some pressure. I'd have the pan dropped ASAP and have the oil pump checked.
If the pressure sensor was bad, it would tell you so. Can't hurt to test it but I would think your oil pump should be checked anyway.
