What kind of rotors are you using? Stock rotor? On two occasions with new stock rotors, had unusal brake feel and brought them to shop for machining - mind you that these were new and had to be cut before all was well.
If this is all they need, that's one thing. But if you have a shop cut the rotors and the problem is not cured, it might void BMA return policies.
More prudent to just request a new set of rotors. I wouldnt worry about replacing the pads as you didnt really put use to them. New rotors and proper bedding with the Hawks shouldnt give you any problems
As for the paint, did you paint the braking surface of rotor or just the hub and outer edge?
Support your American Flag Merchant Marine
No BMW at this time, eyeing a 91 318iS. 00 Saab 9-5, 89 Bronco XLT, 05 Kawi Z1k, 00 Ducati 748S Bip
