to the 520..otherwise it looks like all 5's and 7.s take the same part number in e32 and e34 that is. I don't thinks so on the lkm though.
Originally Posted by bigtallsam
hi all!,
are ccm's and lkm's fairly universal things or are the model specific?
sorry if it's a stupid question, i know a breakers that wil let me have these things extremely cheap and might try replacing these first (namely the ccm) then go hunting for faults if this doesn't cure my 'check control' message
thanks
s
i was more concerned with the ccm so hopefully you've answered my prayers!? i've re-soldered the ccm but i think it's on its way out so i'll try a replacement from the breakers tomorrow (it's from a 520 i think and mines the 525) so fingers crossed, no more 'check control message'
i'll let u know
thanks again
s
the lkm differs between certain models. i know that the 540 has a different one than the 535, for example. however this could be only during specific years yes.
that doesn't tell you much but at least it does tell you that one lkm won't work in all e34s..
-inc
'91 e31 850
'90 e34 535
'02 CBR F4i stunt/track bike
'07 gsxr 750 stunt bike
just got a ccm and an lkm for the bargain price of £5!!
not sure if the lkm's the same as mine yet but it was worth havin anyway
think i'll do a solder job on the ccm before i put it in just for good measure!
s
hi again
the lkm currently installed is part no. 61.35-1 379 372
the lkm i just picked up is part no. 61.35-8 350 375
will the one i just bought work ok or do i stick with the original lkm
thanks
s
etk but the supercession listing for your part is here, these are all the replacements that have taken place over the years
just tried replacing both the ccm and lkm, i think i have success!!
no brake light circuit message and no check control message
all the lights seem to work fine so i assume the lkm i got is ok for my model
have tried to test the ccm operaion by removing a brake bulb and setting of with the hand brake on and leaving the drivers door open and all the usual warnings pop up
thanks for the reply bill
s
s
test
