Results 1 to 7 of 7
Thread: Disconnecting the battery when the engine is running
    Aug 2005
    Default Disconnecting the battery when the engine is running
    What will happen if I disconnect the battery while the engine is running? Will the engine shut down or continue running?
    VIN: GG45422
    Dec 2005
    Mt. Vernon Ohio
    It will shut down. Atleast mine did when my battery terminals were loose
    NovceGuru
    1993 525iA M50TU
    Black on Black...need pics
    208,888 miles
    Aug 2005
    Quote Originally Posted by NovceGuru
    NovceGuru
    Mine also shuts down if I disconnect the battery. I currently have a problem with my battery, it got drained. There is a seperate thread on that. I was thinking if my alternator was faulty.
    You see the russian made cars engines continue running even after you disconnect the battery.
    VIN: GG45422
    NEVER disconnect the battery when engine is running. In worst case you can have heavy damage to your electronic systems.
    baton rouge, loserana
    that's a bad thing to do to a computer controled car, with nothing for the alternator to push against and regulate itself by you get a massive power surge when you dissconnect the battery, yes the car may stay running but you can fry some stuff too
    Bethlehem, PA
    Really *REALLY* bad idea.
    Google battery & alternator & "load dump"
    Aug 2005
    Newton, MA
    Did it on a 92 geo prizm... was alright afaik
    -Artem
  1. Does disconnecting the battery reset the trans comp?
    By brosher in forum 5 Series BMW
    Last Post: 04-12-2008, 06:41 AM
  2. Replies: 1
    Last Post: 10-07-2007, 10:01 PM
  3. Rough running engine and need help
    Last Post: 01-25-2007, 11:23 AM
  4. Engine running on after shutdown
    By uktom in forum 5 Series BMW
    Last Post: 12-06-2006, 07:16 PM
  5. Engine is running even after ignition is off
    By nsbone_1988_520i in forum 7 Series BMW
    Last Post: 04-11-2005, 08:37 AM
