Hi Mike,
I like to use a broad, flat blade screwdriver.
Don's page is here:
http://www.nmia.com/~dgnrg/
best, whit
Can somebody point me in the direction of an injector swap page. I've got the car apart except for the black wiring loom off the injectors and the fuel rail. Plan was to do the injectors, clean and polish the valve cover and adjust the valves/change plugs.
I've pretty much got it all done but the injectors. Did this 3 years ago but having a senior moment.
Mike Holbrook
Meridian, Idaho
Hi Mike,
Don's page is here:
best, whit
http://dl.bmworg.ru/book/haynes/3&5_04.pdf
Haynes manual pdf. page 18 - Renewal on right side of page
Got it, found it on Gale's Page. The injectors are in and valve cover is drying right now. I'll recheck the valves in the AM and button it all up. Thanks for the help.
Mike Holbrook
Meridian, Idaho
Mike, what're you using to polish the valve cover?
best, whit
