Results 1 to 10 of 12
Thread: Need advice on power steering hoses for a 95 540i
    Seattle, Washington
    Default Need advice on power steering hoses for a 95 540i
    I purchased the car (95 540i) last August and have slowly been work on it over the winter. I dont think I've even put 500 miles on it yet. Anyways, before I purchased the car I had a buyers inpection done at a BMW dealer. One of the things on the inspection was replacing the power steering hoses (the pressure hose, tank to pump hose and tank to cooler hose). I do have leaks. The leaks I can see are both hoses from the power steering canister are leaking. The smaller hose from the canister that runs a short ways is leaking from that attachment. Yes, I have checked the hose clamps and they are tight . I see what appears to be fluid that has runs all along the frame rail. My questions and advice I need are: Is this a repair I can do myself or is it best to take it to a shop? If I can do it myself how tuff is it. Has anyone done this that may have some hints? Not much info in the Bentley on the subject for the 540i. Any info and advice would be great and very helpful. Thanks in advance.
    P.S. Sorry so wordy
    Atlanta, GA
    Default Check out the responses to my recent query...
    PS hoses on the M60 are not for the faint of heart...
    http://www.bimmernut.com/wwwboard/e3...ges/57982.html
    Either way you go, good luck.
    Dallas, TX
    Default Specifically, see my response...
    ...back when I was "RC" and not "Super90"
    http://www.bimmernut.com/wwwboard/e3...ges/58055.html
    Robert Callaway
    Dallas, TX
    '94 530im 143k mi
    '94 Land Cruiser FZJ-80 202k mi.
    "If I could have back all the time and money I ever spent on cars.......I'd spend it all on cars."
    Whew! Thanks for the heads-up. I have been contemplating the job myself...I think I'll stick with topping her off with fluid for the mean time, at least wait till it warms up outside.
    I recall reading something about replacing the PS lines with a blue "something or another" lines (help me, having a brain fart). Does anybody have any info on these replacement lines? Where to purchase? Does it make the job easier? The correct name?
    Atlanta, GA
    Default A true Bimmernut solution. . .
    These would be blue aircraft-grade hoses. You would have to get the specs of the hoses you need and have them custom-cut from the appropriate airplane supply source . . . someone else may have that? They won't make the job easier, just should make them last longer (seems like the stock ones on the M60 last roughly four years).
    Thanks! Hopefully someone can and will share their specs. Since changing the hoses is such a pain in the a**, a four year life span is not acceptable to this bimmernut. In-the-mean-time, I'll start doing research on the blue aircraft-grade hoses and I'll be sure to pass along any data I collect.
    Dallas, TX
    Default I am guessing that....
    ... the blue hose they are speaking of is silicon, which is much better at dealing with heat than more typical automotive hoses. Heat is exactly the problem here as these hoses run relatively close to the left exhaust headers which eventually take their toll. Consequently, BMW even puts a silver protective sleeve on the hoses in the section that is exposed to the heat the most. As to where one would get silicon hose made up for this application, that seems like a real challenge. I would just stick with OEM on this, in spite of the know issues.
    In my earlier post, I am not saying that the P/S hoses are not a DIY item, only that they are a pain to get too and small hands are a big plus. Consult your favorite independent and study the situation really well.
    It obviously can be done with hand tools and a floor jack, it's just not the easiest job to tackle right out of the shoot.
    Robert Callaway
    Dallas, TX
    '94 530im 143k mi
    Seattle, Washington
    I guess I even have more thinking to do if I want to tackle this one. Sounds tuff. All the replies so far have been very helpful. THANKS!
    Apr 2004
    cali
    Did you ever have a chance to get these hoses replaced? I know mine are leaking pretty bad. I want to get this done. I have been replacing things and cleaning up oil leaks like no tomorrow. Now i see power steering fluid leaking. Do you know if there are instructions posted on how to do this?
    Bart Guest
    Default Power steering pump reservoir hose leaks
    Are you sure it is the hoses that are leaking and not simply the clamps? My '90 535ia had constant leaks due to the factory one-use clamps not being adjustable: Over time the hose walls had compressed, but there was no way to tighten the clamps, so the connections leaked. Maybe the situation was aggravated by engine and tranny mounts that were shot--the engine had settled somewhat, putting some tension on the reservoir hose, and further stressing the clamp. Replacement with tightenable stainless clamps made a big difference--the reservoir connections no longer leak. Replacement of the engine & tranny maounts will raise the engine a bit, too, so ~1 inch of each reservoir hose can be trimmed to remove the damaged part, and the clamps will then grip "unused" segments of the hoses.
  1. power steering hoses
    By lowerlover in forum 5 Series BMW
    Last Post: 04-26-2008, 01:43 PM
  2. 540/530 guys: DIY Power Steering Hoses?
    By RX7guy in forum 5 Series BMW
    Last Post: 09-12-2007, 06:40 PM
  3. Power Steering Hoses
    By Vanguard in forum 5 Series BMW
    Last Post: 10-27-2006, 11:47 AM
  4. How much of a PIA are the M60 power steering hoses?
    By charlie in forum 5 Series BMW
    Last Post: 07-28-2006, 07:49 AM
  5. Power steering hoses and pump
    By ejhiggins in forum 5 Series BMW
    Last Post: 01-22-2005, 06:43 PM
