Results 1 to 7 of 7
Thread: Whats the knocking noise when i turn left? plz help me :(
    Default Whats the knocking noise when i turn left? plz help me :(
    When i turn left sometimes i hear some knocking noise it sounds like its coming from passanger side front or back not sure, after when i go strait it knocks for awhile reducing the knocking and then stops what can that be please help me out!
    Its mostly hepeneds when i do sharp turns.
    New Milford, Ct
    bad wheel bearing, or bad CV joint.
    Support your American Flag Merchant Marine
    No BMW at this time, eyeing a 91 318iS. 00 Saab 9-5, 89 Bronco XLT, 05 Kawi Z1k, 00 Ducati 748S Bip
    West Palm Beach, South Florida
    Normally, I would be way off base with a suggestion like this, but considering your other post is regarding low oil pressure, you might be starving the engine for oil.
    Default I'd agree here...
    sounds like bad cv-joint on a rear half shaft.....
    Quote Originally Posted by Kobe Diesel
    Maryland, Virginia, D.C.
    Knocking, as in engine knocking, or popping, as in your cv joint is about the break off and throw your tire across the road? Please discern the difference if you can.
    noo i know its not engine its probably a cv joint at the back when i turn left and the car leans to the left when it lifts the back alittle it starts popping. but when i stop turning go strait, it goes away slowly reducing the noise. i checked cv boots they are not cracked.
    The cv joint sounds broken. Find a good honest shop, not a dealer, to replace it. It takes a bit of work and it's dirty as hell to complete it properly.
    And did you know that you don't use punctuation in your sentences? Instant Messenger is bad for you, Mmmkaaay...
  1. Knocking Noise
    Last Post: 10-12-2009, 04:26 PM
  2. Knocking sound when I turn the wheels
    Last Post: 07-04-2006, 05:50 AM
  3. OT: whats so wrong with a normal turn signal stalk?
    By xphilter in forum 5 Series BMW
    Last Post: 09-20-2005, 03:23 PM
  4. Replies: 8
    Last Post: 03-22-2005, 03:19 AM
  5. knocking rear noise
    By epp in forum 5 Series BMW
    Last Post: 07-23-2004, 03:07 AM
