Results 1 to 5 of 5
Thread: Fluid questions
    Minneapolis, MN
    Default Fluid questions
    I can't find the following:
    Ventil-sauber
    Jectron (is that like techron for injectors?)
    CHF 7.1 power steering fluid (mine is low and acting funny)
    Where can I get these? BMA's site didn't have any of 'em.
    Also, has anyone used the vMax stuff they sell at PepBoys in the cheesy beakers? Someone told me those products made a noticeable difference with his truck. If no one has used them, I think I'll try.
    Thanks in advance,
    BennyM
    Minneapolis, MN
    Default bump....didly
    Quote Originally Posted by BennyM
    Ventil-sauber
    Thanks in advance,
    BennyM
    Default The CHF fluid can be found at any BMW dealer or many
    online BMW parts sellers. I am certain that BMA has it as I got it there a few years ago. Also, I believe that Volvo or VW dealers might have it. Also, I did find it at a local parts store - O'Riellys, but it was much more expensive there.
    I simply did a search on the internet for CHF - the brand I have is Pentosin. You should come up with several sources.
    Ventil-sauber
    Thanks in advance,
    BennyM
    Default Like Dick said you can get chf 7.1 from bma, and ventil sauber is just a
    intake valve cleaner, it doesn't work any better than techron valve and combustion chamber cleaner, its just a european name... Jectron is the same company (lubromolly) injector cleaner, I haven't found any of them to work any better than Techron or bg44k.... In fact the only lubromolly product I really like is their copper based antiseize.. If you insist on lubromolly products I'm pretty sure that BMA sells them too if you call them up and ask.. if not almost any small import parts store will have it.
    Ventil-sauber
    Thanks in advance,
    BennyM
    Minneapolis, MN
    Default Thanks. Good thing I already got Techron.....but
    what about that vMax stuff? I am really curious.
  1. Brake fluid loss - questions
    By Adnan in forum 5 Series BMW
    Last Post: 12-09-2007, 11:59 PM
  2. Replies: 12
    Last Post: 12-19-2005, 12:57 PM
  3. Fluid
    Last Post: 11-14-2005, 07:46 PM
  4. Trans. Fluid Change questions, A4S310R....
    By MO525 in forum 5 Series BMW
    Last Post: 04-11-2004, 06:51 AM
