I'll bet you a pizza that it's the sway bar links. They can be hard to spot because if there's any tension on the bar at all, they'll look tight. You have to sit the car so all pressure on the sway bar is relieved and then you can feel whether they're loose or not. Crawl under it and have someone put some pressure on one side or the other to tilt it slightly until the bar loosens.
