uhhh pardon my ignorance but what are you looking to do? a transmission from a 525 into a 535?
Would an 5-spd getrag 260/5 bolt up to the M30 enigne, but have a different ratio than the Getrag 260/6 that came in the 535s?
I looked on realoem, but I want to know for sure and what would be the downfall to using the transmission...
Someone who maybe done this before?
Thank you all
-Artem
Just looking to acquire some information to determine whether I would be able to acquire some M30 clientelle for my endeavour.
-Artem
sounds spooky bro!
yessah
balls!
I dont thing they are interchangeable, maybe between diffy years of the 525 but not across the board to a 535..just guessing though.
Realoem shows a same exact transmission picture.. Long as the bolt pattern is the same on the bellhousing - it should be fine.
-Artem
click the picture then look at the part number, I doubt they would use a 535 trans in a 525 car, dude go for it!!!! Im all for it, just make sure it will work, look at pressure plates and clutches too.
Originally Posted by ArtemLepilov
I wouldnt do it if anything though - unless angry wants to do it I got an M50 and it doesnt bolt up to that fo sure
-Artem
