Results 1 to 5 of 5
Thread: difficultly starting. please help.
    Default difficultly starting. please help.
    I am having difficulty starting my 92 535i. I need to step on the accellerator to get it to start. Some times the check engine light comes on and I get nothing when I step on the gas. I need to give the acceration a push and it goes away. Most of the time I experience this when I starts the car. I just replace the spark plug, the wires, the distributor cap and rotor. any suggestions? I might check the fuel pump and the fuel filter next. any suggestion? thanks in advance.
    Quote Originally Posted by bluex5
    Your Crank/rpm possition sensor, coolant temp. sensor, MAF sensor should be checked out according the Bentleys. If any of these are bad the car have problem starting
    Norcross, GA
    Check the fuel filter too. A clogged one can give wierd problems.
    Arun
    Auckland, New Zealand
    And the fuel pum - it has a back flow valve thingy that can fail on older pumps and therefore the fuel drains out of the lines back into the tank over time. That may be also a contributing factor. I would suggest you follow nariusb's suggestions and also check the fuel pump.
    Freude am Fahren - Damn straight!
    Honolulu
    Default Idle control valve
    clean it with some throttle body cleaner.
    Do you smell gas once the car has finally started?
  1. Car not starting...
    By Travis_WA in forum 5 Series BMW
    Last Post: 10-22-2008, 08:23 PM
  2. Non starting M60
    By Sidney Rough-Diamond in forum 5 Series BMW
    Last Post: 01-28-2007, 04:46 PM
  3. Starting, need help
    By zivac05 in forum 5 Series BMW
    Last Post: 07-12-2006, 02:27 PM
  4. car not starting right away
    By wang540 in forum 5 Series BMW
    Last Post: 11-17-2005, 09:07 PM
  5. Not starting
    By ken in forum 5 Series BMW
    Last Post: 09-02-2005, 11:41 PM
