Results 1 to 10 of 12
Thread: Open or LSD?
    Default Open or LSD?
    Hi Guys,
    I started a thread requesting information about the e28 535i gearbox but it seemed to have pulled a Houdini on me. It was either tossed or got deleted during the server crash. I was hoping to post this question on the same thread.
    The guys who did respond to the initial thread however, were all correct with the info given as I now have the gearbox out and it confirms what they said it was.
    I just pulled the diff and thought it would have been an LSD since it came from an e28 87 535i I am a bit confused because the diff tests as an open one but yet the top has some indication of having the 2" stencil "S" on top as in the pic.
    I tried brushing the stub axle bolt tabs but still can't see any proof of it being an LSD.
    Any ideas?
    Thanks.
    BMW, THE ULTIMATE FLYING MACHINE
    SPEED AND POWER IS NOTHING WITHOUT CONTROL,
    THANK THE GERMANS, BMW HAS ALL 3
    Hockinson, Washington
    Its "limited" slip. 24% i think. that means it allows some slip, maybe enough to pass your test.
    Edit: thats if its an lsd of course.
    That's because most high mileage LSD units have worn out or bad frictions.
    Most of the units I pull apart seem to be done before 150k.
    Pull off the back cover and have a look. Or take a picture and post it if you're unsure of what the LSD unit looks like.
    best, whit
    from that pretty picture I cant tell much, is there an aluminum tag on one of the bolts with numbers?
    Quote Originally Posted by lowell
    best, whit
    Whit, I was thinking the same being worst case scenario. I was really hoping it was not a wear issue, but as you have indicated, may very well be.
    This diff has 152,000 KM so 94,500 miles
    I will take some pics and will post tomorrow.
    Thanks allot Whit.
    I checked very quickly when we pulled it and I think I saw one but it seemed too corroded to distinguish any markings.
    Not that hard to replace the clutches. Never done it without a press, but I'm sure it could be worked out, a la Bidoli style.
    best, whit
    Elm Grove Farm, NC
    Quote Originally Posted by Turbo Ready
    Scrape the crud/corrosion off the tag with a knife or scraper blade- the diff ratio and possibly an "S" is stamped into the metal tag- you should be able to see it once you scrape that crap off...
    Or, it's pretty easy to remove the rear cover like Whit said- and have a look-see at what you've got.
    Bret.
    best, whit
    I have a press Whit, but have never changed LSD clutches before, guess there is always a first time. I do quite a bit of automotive work and would love to tackle it. I guess BMW sells the replacement clutches Whit?
    Thanks.
    Quote Originally Posted by Rigmaster
    Bret.
    Bret,
    I will pull the rear cover off tomorrow and will upload some pics.
    Thanks.
  1. Steps to open up DME ECU box on E34
    By ktteoh in forum 5 Series BMW
    Last Post: 12-03-2005, 05:49 AM
  2. How do I open up the MAF?
    Last Post: 10-02-2005, 11:19 PM
  3. Hood Open, Door Open, Trunklid Open
    By MDT in forum 5 Series BMW
    Last Post: 07-20-2005, 02:25 PM
