I wouldn't mess with the ignition. If you are putting the changer in the back you can probably tap into amplifier turn-on wire (turns on only when the key is in run position). The amp is right in the trunk anyway.
P.S. The best way to run power wires(not speaker) from front to back is on the passenger side. The carpet comes right off and you can neatly hide all the messy wires.
