fyi rotate/bal. every 5,000
I have 35,000 on set of bridgestones with about 1/2 tread left and seem to be worn even. I do this because the rear tires will wear on the inside and front tires will wear on the outside.
BTW, my tire shop uses a torque wrench on the lug bolts. But they will not use weights for an alignment. Not sure the dealer even does here in Lexington, KY.
Originally Posted by
Tiger
How often did you rotate the tires? How many miles on them?
