Thread: While we are on the subject of doors not opening
    Melbourne, Australia
    Default While we are on the subject of doors not opening
    My drivers door does not open fully. You know how it has notches with resistance as you open the door, my last notch is the full extention of the door. Before I rip it to bits, has anyone seen this before??
    1990 BMW 535i Exec
    baton rouge, loserana
    the door brake aka door check has probably died, it's not hard to replace and it should be replaced before it rips the end out of the door as that's not a easy repair 51 21 8 155 698 should cost around $30
    Lexington, Kentucky
    Driver's door makes noise when opening, sort of scraping noise. What's going on here?
    it ether needs some lube or it's on it's last leg, id change it as they can do some damage when they crap, seen em take out the window regulator in rare cases and busting out the end of the door is common
    Thanks guys. I still cant understand what you mean but I suppose I will find out real fast when I get inside the door.
    1990 BMW 535i Exec
    Thanks guys. I still cant understand what you mean but I suppose I will find out real fast when I get inside the door. Can the part be easily saved or manufactured at home?
    1990 BMW 535i Exec
  1. Opening rear doors if power fails
    By Paulandjen in forum 5 Series BMW
    Last Post: 12-28-2006, 04:13 PM
  2. Subject of Cats
    By old bob in forum 5 Series BMW
    Last Post: 05-09-2005, 10:08 PM
  3. Old Subject:Trans Program
    By ExcessPlay in forum 5 Series BMW
    Last Post: 02-08-2005, 03:21 PM
