you don't need anything other then a set of metric wrenches and sockets, the weirdest thing on there is the 32mm on the fan clutch, 2.5mm allen on the rotor if it's bosch and 3mm if it's the crap aftermarket italian rotor
I am about to get my timing belt changed but have been told that a couple of special tools are required. Never heard of this before can anyone enlighten me
Thanks Winfed how long should it take to do the job. It gives me the s..ts that you have to check everthing out nowdays so we don't get ripped off.Originally Posted by winfred
takes me a couple hours to do belt tensioner and water pump on a m20
Book is 3 hours for the belt itself, I think. Don't know the specifics on the water pump. If doing it yourself without prior experience, allocate a weekend, especially if the car's been subject to rust. Otherwise, a shop should charge something around 4 hours for the job, or less if they're nice. It's not a complicated job -- a money maker on the ETAs, as it can be done in less than half an hour. I motors take a coupla hours.
best, whit
As a novice I was quite concerned about getting the tension right but it really is very straight forward - If I could do it, anyone can do it !Originally Posted by old bob
Take your time and change the tensioner pulley too.
Bentley give lots of detail - read and absorb before you start.
"I'm not the village idiot.
Thanks for your help will let you know how I finish upOriginally Posted by lowell
HAPPY EASTER All
IMPORTANT
After you think you have finished, rotate the engine by hand using the 32mm fan bolt, and make sure it turns freely (at least a couple of complete engine revolutions), if you meet any resistance you could have got the head misaligned - always best to do this rather as use the starter motor because if there is a fault, you will wreck it trying to start it.
I haven't heard any horror stories for the M20.
Is it easy to come off, or what?
Just checked out my Bently's...and, as long as the front crank seal is good, it's just a matter of unbolting the pulley/harmonic balancer from the flange on the crank.
