Results 1 to 4 of 4
Thread: removing camshafts - M50 nonTU
    The Netherlands, around Amterdam (as every place is)
    Default removing camshafts - M50 nonTU
    Hi all,
    I was reading an interesting Pelikan article on the net about removing camshafts without the BMW special tool ... my main obstacle for not replacing a noisy lifter.
    Apparently while turning the cs there is a spot where only the #1 lobes are under spring pressure, the rest isn't ... Once this spot is found you can remove all other bearing caps without any risk of bending/breaking the cs. The last step is evenly removing the cap closest to cilinder #1.
    What do you guys think? Sounded plausible to me ...
    BTW a very entertainging site about DIY on V12 E32's: http://bmwe32.masscom.net. A lot of things are applicable to E34's as well.
    Cheers,
    John
    East Brunswick, New Jersey
    I removed both cam shafts on my 525i last year, without the cam locked at no. 1 cylinder TDC (naturally if they are locked they cannot be removed) and without the cam shaft removal tool from BMW. I replaced two valve lifters.
    It was my first E34. I was very careful loosening the cam bearing caps nuts a few turns at a time on both.
    Ignorance is bliss?
    '01 540it, 6/01
    '03 325i 5 speed, 9/02
    '10 535ix. 9/09
    '10 mini 6 speed
    '15 mini countryman 6 speed
    http://www.pelicanparts.com/bmw/tech...ft-removal.htm
    Entertaining article which strongly advises against your method yaofeng :-) maybe it isn't that bad if you do it very carefully. Why didn't you replace all lifters, they aren't that expensive are they?
    Cheers,
    John
    I removed all the lifters as you can see. Why replace only two? Only two are bad. I did not remove the camshafts because I found valve chatter or anything. You probably can tell from the picture the engine has sludge. I did my best to clean it.
    '01 540it, 6/01
    '10 535ix. 9/09
    '10 mini 6 speed
  1. How about removing the SRS bulb?
    Last Post: 01-15-2008, 09:15 AM
  2. Help - Removing M60 4.0L V8
    By Panzer Captain in forum 5 Series BMW
    Last Post: 10-14-2007, 01:39 PM
  3. Removing A/C
    By Kobe Diesel in forum 5 Series BMW
    Last Post: 02-18-2006, 02:23 PM
  4. Removing the ECU?
    By TheGeak in forum 5 Series BMW
    Last Post: 02-18-2005, 12:38 PM
  5. Replacement camshafts
    By SIXPACKDREAMER in forum 5 Series BMW
    Last Post: 04-30-2004, 02:30 PM
