The short answer is "no". The offset is usually off by so much that you'd spacer yourself out to shimmyland in a heartbeat.
Do any 3 series wheels from late models work? Such as year 2000 and newer? I found a nice set of from the 2002 model year that are nice but not sure. I have read in the past that 3 series dont work but don't really remember.
Is there a thread started that shows guys useing differant stock wheels from other models on there cars? or a spread sheet to this end? Thanks fellas!
not without about a inch of spacer which will make you miserable in the 50-60 mph range
e 34.net will tell you all you need to know about the e 34,incl what wheels will work
Gone but not forgotten
20mm spacer.
you will damage wheel bearings with the needed spacer size..Originally Posted by Exnilo
deleted air conditioning
Rubbish.Originally Posted by Rustam
If the spacers put the wheel in the same relative position as a standard E34 wheel, the forces on the hub and bearing are the same. Leverage...
If you have a hubcentric spacer and the proper mounting hardware there would be no problems. Porsche reportedly used spacers on various 911s for years. Good ones are expensive though.
Anthony
03/64 production
