Thread: M30 Injector upgrade
    Aug 2004
    RTP North Carolina
    Default M30 Injector upgrade
    Ok here's the question. What benefits if any to going with new 4 hole style 19Lb injectors over stock? What about new 4 hole style 22Lb injectors? Improved gas mileage? Better idle throttle response?
    Quote Originally Posted by smcgowan
    Pretty much none of the above I'm afraid. Bigger injectors will be fired less once the computer senses the exhaust output, so you get no real improvement. BMW spec the injectors the way they want them (spot-on) in the first place; Aftermarket replacements are no way near as perfect. With an M30 some of us can get away with using 19lb injectors, but I don't detect any real improvement over (good) stock ones. If we had turbos it'd be a different story.
    Mileage is the first thing to suffer from a poor choice btw.
    Albuquerque, NM
    I noticed a smoother idle & perhaps a tiny bit more power with 19 lb/hr Series II injectors. Probably mostly because they were new but also partly due to a finer droplet size and a better dispersion pattern which produces a more complete burn. I did pick up a little better mileage with them.
    gale
    tempe
    larger injector does't necessarily mean more power you would probably will just run rich and not pass emission and the your air:fuel ratio will be so terrible like he said the real reason tyo upgrade injectors is in a turbo setup where your adding air as well as fuel.
    Hockinson, Washington
    I needed new injectors, and i found a good deal on the design III 19lb injectors, so i bought them. The car runs more smoothly and more quietly.
    Aug 2004
    RTP North Carolina
    Default Thanks for the responses
    I found a set of the stage III injectors for pretty cheap and before a jumped on them I thought I’d ask. I thought since the newer patterned it should yield a smooth/cleaner burn, but I thought it be best to throw the question out.
    Anybody with the M50 with any input?
  1. M30 and M50 Injector upgrades
    By smcgowan in forum 5 Series BMW
    Last Post: 04-18-2006, 07:11 PM
  2. Help Injector Swap
    By mholbrook in forum 5 Series BMW
    Last Post: 03-18-2006, 09:38 PM
  3. Injector Harness
    By stargazer_61 in forum 5 Series BMW
    Last Post: 12-26-2005, 03:02 AM
  4. Injector leaking ?
    By Black530i in forum 5 Series BMW
    Last Post: 08-30-2004, 07:02 AM
  5. Replies: 2
    Last Post: 04-02-2004, 02:29 PM
