Originally Posted by
JScritch
Ok, I've read the owner's manual and I'm still not getting it. What exactly does the A/M switch next to the gear selector do?
When I put the car in "D" the dash displays "ED" and when I put the car in "3" the dash displays "S3" but nothing happens in either setting with I try to use the A/M switch.
Is the dash display supposed to change depending on whether I select A or M?
Is the A/M switch supposed to light up when I select one or the other?
Is it possible I have a faulty switch that could be causing some of my "trans program" errors?
I pulled switch and sprayed it real well with contact cleaner since it had a lot of gunk on the outside of it, but maybe it's still bad.
