Results 1 to 7 of 7
Thread: 535i 89' stomp test
    Raleigh, NC
    Default 535i 89' stomp test
    Will the "stomp test" work on an 1989 535i? I thought I read somewhere that a bulb was missing or something of that nature and would not display the codes? Is it not even equipped with the stomp test? Any idea?
    Sep 2005
    southeastern, CT
    i have an 89 535i and the stomp test works.
    It probably depends on the date of manufacture, i'm sure someone else will have a more detailed explanation.
    89 535i/5
    90 535ia 158k
    90 Infiniti Q45 (sold)
    91 Sho (sold)
    94 530i/5 (sold)
    95 855 T5 @15psi boost
    Raleigh, NC
    Also, how do I know that it works, like where do the codes show up at? And if no codes show I'm assuming that there are no problems, right?
    Sep 2005
    southeastern, CT
    Quote Originally Posted by LAXman2205
    The codes will show up as flashes of the check engine light, like morse code.
    read this: http://www.bmwe34.net/e34main/trouble/engine_codes.htm
    89 535i/5
    90 535ia 158k
    91 Sho (sold)
    94 530i/5 (sold)
    Raleigh, NC
    Quote Originally Posted by gt90
    As you can see I am a newbie at these sort of things, how do you know which code is which? I see the light blinking but how do I know that the code is, for example 1224?
    Sep 2005
    southeastern, CT
    The light will blink twice and then start showing codes.
    a code of 1224 would be
    1 quick blink....pause.....2 quick blinks.....pause 2 quick blinks.....pause 4 quick blinks. keep reading the codes until it repeats the first one again.
    It's easiest to make slash marks as it blinks the codes and then figure out what they are after. example 1224 would be | || || |||| the spaces in between being the pauses.
    89 535i/5
    90 535ia 158k
    91 Sho (sold)
    94 530i/5 (sold)
    Raleigh, NC
    Been a lot of help bro, thanks for the patience.....
  1. Stomp Test
    By SLIPPERY in forum 3 Series BMW
    Last Post: 05-30-2006, 05:44 AM
  2. Stomp test...
    By TheEndIsNear in forum 5 Series BMW
    Last Post: 05-13-2006, 02:03 AM
  3. Stomp Test help
    By Springfield1952 in forum 5 Series BMW
    Last Post: 02-21-2006, 07:36 PM
  4. What to do with no stomp test...
    By wengenstein in forum 5 Series BMW
    Last Post: 11-17-2004, 05:36 AM
  5. Stomp test..?
    By ilya in forum 5 Series BMW
    Last Post: 03-17-2004, 11:11 PM
