Results 1 to 7 of 7
Thread: Dead Cluster display
    Honolulu
    Default Dead Cluster display
    Trying help out a friend.
    95 525
    The LCD display in the gauge cluster is dead, back lights work, ran the diagnostics and the gauges all work, but no text, no Odometer, no trip meter, oil/service lights are dead too...even the shift letters.
    Checked the OBC, and it working.
    Any ideas?
    Nov 2005
    Sarasota, FL
    I know these gauges have problems with lights and capacitors after some time, no idea if that is the problem.
    I was wondering if there is someone that will rebuild your gauges for you....or at least the lights and capacitors. I just don't have the time right now and don't want to cost myself a couple hundred bucks if I screw my current ones up.
    Everything is operational on mine except some backlighting and both stalks don't function.
    91 535iA M30 Auto
    Born in 3/91 (The Bimmer, not me )
    120,000 Miles
    Pics soon--she is a work in progress
    Honolulu
    Default The lights are easy
    Try to shine a flashlidgt at an angle to see if the text and numbers show up. it so, it's just the lights. an easy fix.
    it's the funky stuff, like the caps, or guage replacement that gets tricky.
    Nov 2005
    Sarasota, FL
    It's definitely just the lights. I can see the odometer turning when the light hits it right, just isn't backlit anymore.
    I think I have some capacitor problems as well because I can't reset anything using the push-stalks.
    91 535iA M30 Auto
    120,000 Miles
    Honolulu
    Default My is out scouring the junkyards
    for another cluster.
    will the coding plug transfer his old mileage data to another cluster?
    all data are in the coding plug, including the chassis number and the mileage.
    So the mileage is in the coding plug and that one has to go in the replacement cluster.
    On early E32 models the coding plug was outside the cluster in the wire loom, later models had it inside the cluster. Not surehow that is on E34.
    Nov 2005
    Sarasota, FL
    If you look on Bruno's site there is an explanation of years that had the plug in the loom and when they switched to in the cluster. I think ultimately the best way to find out is to pull the cluster because you also need to know the color of the backside.
    91 535iA M30 Auto
    120,000 Miles
  1. LCD Display on E39 Gauge cluster
    By SnakeyesTx in forum 5 Series BMW
    Last Post: 05-03-2008, 12:24 PM
  2. Info cluster next to stereo went dead...
    By vuyodaddy in forum 5 Series BMW
    Last Post: 07-07-2007, 06:26 PM
  3. question about the display on the cluster
    By wang540 in forum 5 Series BMW
    Last Post: 02-01-2006, 11:43 AM
  4. Instrument Cluster Mileage Display Help
    By mustard in forum 5 Series BMW
    Last Post: 01-28-2006, 01:55 PM
  5. 1999 323i Instrument Cluster analog dead
    By Chrisvk in forum 3 Series BMW
    Last Post: 06-15-2004, 06:49 PM
