Have you pulled all the plumbing off and checked the throttle housing to see if the throttle valves are closing all the way? Sounds like it might be stuck open, so possibly bypassing the Idle Air Control valve entirely. Check things like rusted/bound up throttle cable or cruise control cable, varnish and funk built-up around the throttle valve itself....basically anything that would prevent that throttle from closing entirely.
