Results 1 to 10 of 13
Thread: ::.. Tire Pressure
    T·O·R·O·N·T·O
    Default ::.. Tire Pressure
    The stock suggestion of 29F/33R is too low for cars of this weight IMO. I'd run at least 32F/36R - maybe more. Just keep the 4PSI difference F/R. I run mine at 36F/40R and they are wearing squarely.
    So really, what should we be running then? I agree that 29/33 feels low.
    Dec 2005
    New York
    I run the H&R sport springs, Bilstein Sports, and 18s wrapped with 235/40 Falkens, and have been very happy with 40f/42r. I have found that because of the wide, low profile tires, going any lower tends to make the car (particularly the front) "catch" on potholes and bumps, rather than ride (relatively) smoothly over them. I suspect that these pressures may lead to odd wear patterns as mileage builds though...
    The drivers door will ave a sticker that gives proper tires and tire inflation, you can start with that number and adjust it to meet your needs. the recomendation will be compromise between economy and comfort.
    Calgary AB Canada
    Quote Originally Posted by Qube
    Where did that quote originate? Sounds like something I would have written...
    Anthony
    03/64 production
    May 2005
    Jet City
    My 2500 lb Datsun 240Z runs 225/50-15's and my 3880 lb 530 Touring runs 225/60-15's
    To get the performance and steering definition I run 28 to 30 psi max on the Datsun and no less than 40 psi on the Touring.
    The Touring was vague and wallowed with 32 psi. The ride was smoother and road noise was quieter but the car handled like a drunken pig. 40 psi "almost" put it on par with my sedan.
    Suspension geometry wears out the shoulders of the tire first. Lower pressures will accelerate the process.
    Lower pressures allow the sidewalls to flex more (on a taller tire) generating excessive heat and premature failure. Google Firestone vs Ford and Explorer rollovers. The tires kept falling apart due to (as yet unknown) tires from a certain factory not being built to spec. Ford increased the frequency of failures by recommending a lower psi (why I'll never understand) which caused even more sidewall flexing and MORE HEAT and even more failures..
    Rule of thumb, the heavier the car, the more psi you need. Tire size also determines pressure. The bigger it is above stock size the chances are you'll need less pressure for average driving.
    Hope this helps.
    DJ
    T·O·R·O·N·T·O
    Quote Originally Posted by Spasso
    Hope this helps.
    DJ
    So in a nutshell, when I take these 235/45-17 on the track next week, I should stick to the labelled psi. MAYBE bump up one or two where a passenger is inside.
    Wellington,New Zealand
    the factory pressure for 235/45/17 is 39f41r (or something very close to this)for the M5,its what i run on my 535 mtech suspension and 235 45 17
    Gone but not forgotten
    Lexington, Kentucky
    Best pressure stock tires? I currently use 30/34 for normal driving with one person in the car. However, it seems to handle a bit better at higher pressure but rides much rougher. I see even wear on tires as I rotate/balance every 5,000 miles
    Calgary AB Canada
    Quote Originally Posted by Paul in NZ
    38F/41R IIRC. The 29F is only for the 15" tires - 29 in a 45 series tire is asking for rim damage with a great big PLEASE.
    Anthony
    03/64 production
    So.Calif ( L.A. Beach Area)
    I am running 32 psi F & 35 psi R on 225/60 15" Traction TA's ( V rated) handles awesome and sticks like glue
  1. What tire pressure do you run.....
    By bsell in forum 5 Series BMW
    Last Post: 03-23-2008, 04:37 PM
  2. Tire pressure
    By mitch2k in forum 5 Series BMW
    Last Post: 07-03-2006, 03:06 PM
  3. Tire Pressure?
    By liquidtiger720 in forum 5 Series BMW
    Last Post: 08-10-2005, 07:44 PM
  4. Tire Pressure help
    By kentish in forum 5 Series BMW
    Last Post: 04-17-2004, 09:19 PM
  5. Tire Pressure 101
    By Level8Drummer in forum 5 Series BMW
    Last Post: 03-31-2004, 11:22 PM
