Originally Posted by
joshua43214
You need a master cylinder. This is the first warning that a failing master cylinder gives before total failure.
Ok, that being said, verify the proper operation of the calipers, sometimes a claiper will stick from not properly lubing the slides. when the pad wears down enough, the caliper will slide abrubtly into a new position, causing the brake pedal to fall to the floor.
But back to my first point, You description is indicates a bad master cylinder. Your car has given you fair warning, ignore it at your own risk.
