Results 1 to 8 of 8
Thread: How to replace rear Pitman arms (torque rods)
    Default How to replace rear Pitman arms (torque rods)
    Hockinson, Washington
    That article is accurate and well done with good pictures, but it make is MUCH more difficult than it needs to be. You dont need to remove the rear wheels, or even jack the car up. Just take the bolts off a put new dogbone in and put the bolts back on and torque them. Its as simple as that. The toughest part will be getting a wrench to thtop of the bolt, but even that shouldnt pose too much difficulty.
    Lexington, Kentucky
    I agree, it is much easier than that article mentions.
    Houston, TX
    That's the one I used when I did mine - I found it very helpful. And yes, it's an easy job.
    you didnt take the wheels off?
    Nope.
    No need to take the wheels off. You can just reverse the car onto ramps and remove and install from there.
    I didnt even use ramps.
  1. Rear Pitman arms, What do they do?
    Last Post: 08-23-2007, 04:50 AM
  2. Rear pitman arms (dogbones) failure
    By zmuff in forum 5 Series BMW
    Last Post: 06-27-2007, 07:46 PM
  3. Replies: 0
    Last Post: 06-10-2007, 06:02 PM
  4. Replies: 7
    Last Post: 04-04-2005, 12:54 PM
  5. Replaced rear pitman arms (dogbones) 95 525i
    Last Post: 10-09-2004, 05:56 PM
