Results 1 to 10 of 15
Thread: Air con probs.....help please
    West Sussex, UK
    Default Air con probs.....help please
    My condenser is leaking green dye when car is running. I was recommended some stuff called air con leak stop, but someone else is saying this could cause more damage to the other componants??
    The AC mobile tech bloke (business called Chilly Willies) is due out on thurs but think Ive got too cancel as away.
    The system is still on R12 gas which im keeping that way. Couple of questions - My AC fan never runs on its on and I get loss of power and sometime stooling if parking etc. Its as if its taking too much power from the engine. Any ideas??? Thanks in advance
    By the way im in england so system may be different....?
    Never, ever put a leak sealer in an AC system that uses an expansion valve or a capilary tube. If your condensor is leaking dye, you need a condensor.
    Follow this link to learn every thing you never wanted to know about ac systems
    http://www.bimmer.info/forum/showthr...hlight=factoid
    If you auxiliary fan does not run, dont waste your money fixing the ac until its fixed, your r12 will just leak out 5 times faster and the ac wont cool anyway unless you are moving.
    As for it stalling, search for ICV and stalling.
    West Sussex, UK
    Interesting read, thank you. Few questions though:
    I have a basic knowledge of my car and carry out most work on it. What do you think is up with the fan then, solanoid? Do you think I could do this as DIY? Is the fan meant to run all the time the AC is on?
    So you really think I need to go for a new condenser, simple to fit? Maybe I could just patch it up with something that works really well on rads?
    Its still blowing cold but leaking loads.
    Cheers
    Only way to fix a condensor is to weld it. Even sweating a patch on tends to fail unless very expertly done, there is just too much pressure on the high side.
    I believe than Aux fan on '92 is pressure controlled, so it will only come on when you have adequate pressure. Uness the system is almost empty, it will normaly still create enough high side pressure to operate the fan. Diagnosing and replacing the Aux fan is straight forward electrical stuff, not too comlicated as these things go. there should be a wiring diagram here somewhere, look for the climate and aux fan diagrams.
    http://www.e38.org/e34/
    The condensor itself is simple enough to replace, but you will need to remove the old r12 and then the system must be placed under a vacuum before it is recharged. So you will need your ac guy to come arround and do that at the very least. Make sure he knows you replaced the condensor and that it was leaking heavily so he can add the proper amount of oil, deciding how much oil to add after a leak repair takes experience.
    South Wales UK
    My air temp sensor reads -37 degrees on the obc i found two plug sockets tied up , looked on the net for piccies of the sensors and they match the connections!!! so now i'm asking why would the external air temp sensor and the intake air temp sensor have been removed????...and would this be the reason for me getting no air through my vents even though the fan is on position4 and working and the compressor seems to be running????
    BMW 540i V8 auto Touring 1995 'M' cosmos black abs acs dsc aircon etc. 286 BHP!!!
    Default If the fan is working and the compressor is working then you have a
    plugged up pollen filter or cabin filter, whichever term you prefer. The fan will sound like its blowing its little guts out but not much air will come out. The air temp sensor on the obc is unrelated to the climate control system.
    Quote Originally Posted by bmwman1973
    West Sussex, UK
    My air temp sensor read that until I replaced the sensor in the bumper.
    Where are the cabin filters on E34s?
    Pittsburgh, PA
    Cabin filter replacement compliments of Don Gale:
    http://www.nmia.com/~dgnrg/page_4.htm
    Present: Black 1995 525i | Past: Red 1989 535i; Black 1985 535i
    South Wales UK
    ok cool...can you tell me where i can find this cabin or pollen filter?...your help is much appreciated
    Pittsburgh, PA
    do you have me blocked?
  1. more probs
    By nmwaldron in forum 5 Series BMW
    Last Post: 09-16-2006, 09:38 PM
  2. tick over probs
    By wappy in forum 5 Series BMW
    Last Post: 07-20-2006, 03:15 PM
  3. Starting Probs m51 td
    By Pikey in forum 5 Series BMW
    Last Post: 07-19-2006, 03:52 PM
  4. 3.0 m60 starting probs
    By cortez in forum 5 Series BMW
    Last Post: 07-05-2006, 06:28 PM
  5. Speaker probs
    By bmwman1973 in forum 5 Series BMW
    Last Post: 05-02-2006, 11:51 PM
