Results 1 to 10 of 12
Thread: Just installed a newer General module
    Yorktown, VA
    Default Just installed a newer General module
    I just installed a newer General Module from a 1995 525i into my 04/1989 build 535i. It took care of my irritating lock/unlock twice routine, made the rest of the windows one-touch down (only), and a few of those other cool things the newer GM does. Shogun has posted several times in the past about the newer GM's so I have been on a search for the newest one I could find. Thanks Shogun...no denying you are a GURU!
    Oh, the newer GM P/N I used was 61.35-8 355 818, the one that came out was 61.35-1 379 740.
    zmuff--1989 535i 5-speed--17" E39 Style 32's--JC chip--UUC Short Shift--
    --Racing Dynamics Springs & Sways--Bilsteins--Yorktown, VA
    T·O·R·O·N·T·O
    Few other things? Like what? I don't mind 'upgrading'. I forget if upgrading the LKM gets the light dimmer too... I'll have to search again.
    That is what I found for the E32 new GM:
    -headlight washing pump at fifth windshield washing after time interlock
    -intensiv washing pump operating at reduced time from 3 to 2 seconds
    -minimum interval for wipers reduced to 2 from 3 seconds (programmmable)
    -increased wiper contact pressure during windshield washing now also provided
    -previously the GM would react opposing signals (e.g. an unlock signal while trying to lock, as with a defective microswitch) by carrying out the first command (e.g. locking, followed immediately by unlocking). Repeating the first command then results in carrying out the command, e.g. try to lock again, and locking is now carried out. This function (Asynchronious Position)is omitted in the NEW GM.
    -After unlocking is performed due to crash sensor activiation, the locking command is now reactivated by double-locking with the key from either side (driver or passenger door).
    -The one-touch operation of windows has been expanded to all 4 windows in OPENING direction. Drivers side has one touch in both directions
    Sunroof is not already in the tilt position.
    -switch off delay of the interior lights after entering the vehicle and closing the driver's door reduced from 20 to 15 seconds.
    Default For the daylight
    Resistor Continious Dim Light, U.K. version
    # 6
    http://www.realoem.com/bmw/showparts...61&fg=25&hl=52
    But I do not know if a modified LKM in U.K. version is also necessary.
    Wellington,New Zealand
    what was your lock/unlock behaviour z muff?
    Gone but not forgotten
    He said it:
    yes i wondered if it was an intermittent problem,and guess if it was indeed lock unlock etc or unlock lock etc
    that is one of the big advantages of the new GM:
    Yorktown, VA
    My locks have had no problems on the lock cycle, but the unlock cycle would always take two tries to stay unlocked. I have heard plenty of stories for both scenarios. I've go it narrowed down to the drivers door (not sure if it's the actuator, microswitch, or something else). I'm recovering my interior door panels one at a time, so when I get to that door, I'll fix whatever I find wrong.
    Hockinson, Washington
    Would resoldering this fix a problem where the washers wont stop spraying until the car is shut off?
  1. Upgrading the General Module
    By Kalevera in forum 5 Series BMW
    Last Post: 03-09-2013, 11:38 PM
  2. General Module - E32 vs E34
    By Happy_Go_Lucky in forum 5 Series BMW
    Last Post: 09-27-2006, 07:42 PM
  3. general module repair
    By duckloads in forum 5 Series BMW
    Last Post: 12-17-2005, 08:23 AM
  4. Replies: 5
    Last Post: 12-21-2004, 04:25 PM
